[Qgis-user] Re: [Qgis-developer] Properties dialog too big for
small displays (eee PC display)
Garvan & maew
garvan.maew at online.com.kh
Sun Mar 1 04:33:27 EST 2009
Agus,
I think the shortcut keys Alt-F7 will change the mouse pointer to a hand
in the center of the active screen, and then you can move the window
outside the upper bounds of the desktop to reach the buttons at the
bottom. In my set-up (Ubuntu) this works, while clicking on the system
menu item "Move Window" will not work because the window vertical
position is confined.
It's a handy shortcut to remember on an EeePC, even if it does not work
for you this time.
Garvan
Agustin Lobo wrote:
> Otto,
> the problem is not moving the properties dialog, the problem is that
> it's too large and even moving it to the top I cannot reach the buttons
> at the bottom.
> Agus
> Message: 2 Date: Fri, 27 Feb 2009 08:53:08 +0100
> From: Otto Dassau <otto.dassau at gmx.de>
> Subject: [Qgis-user] Re: [Qgis-developer] Properties dialog too big
> for small displays (eee PC display)
> To: qgis-user <qgis-user at lists.osgeo.org> Cc: qgis-developer
> <qgis-developer at lists.osgeo.org> Message-ID:
> <20090227085308.55a62d04 at nature> Content-Type: text/plain;
> charset=US-ASCII On Fri, 27 Feb 2009 08:44:59 +0100 Agustin Lobo
> <Agustin.Lobo at ija.csic.es> wrote:
> > > I'm running QGIS on a ASUS eee PC 901 under
> > > ubuntu eee 8.04. I find no major
> > > problems except that the GUI panel
> > > for Properties is so big that I cannot
> > > reach the buttons at the bottom and
> > > cannot select OK, thus no way of
> > > using it. I cannot resize the window to
> > > make it smaller. The display is 1024x600
> > > Any solution?
> pressing keys (Alt + 5) together you should be able to click on the
> properties
> dialog with the left mouse button and move it upwards (or whereever).
> hth
> Otto
