[Qgis-user] some problems
Alex Mandel
tech_dev at wildintellect.com
Wed Mar 4 06:17:01 EST 2009
ivan marchesini wrote:
> After installing 1.0.1 in my debian testing I have found these strange
> problems:
> 1) if I try to have a look at table of grass vector layers I can see
> only the cat column.. not the others columns (both in dbf and postgres)
I wonder if the attribute table is not attached properly. Have you tried
v.db.join and specified the table to use with the vector layer?
Were these layers in grass already or did you import them with QGIS?
> 2) if I try to split linear feature I obtain a Qgis crash, both using
> shapefile and postgis layers...
Could you clarify, are you using the QGIS built in Editing toolbar,
Split Features command. Does it work on a polygon?
Thanks,
Alex
