[Fwd: Re: [Qgis-user] Projection not recognised EPSG:31259]
Werner Macho
werner.macho at gmail.com
Tue Mar 24 07:15:28 EDT 2009
Thx for your answers!
But .. I assume a delivered projection file as correct - and you did not
say that government fails or the projection is wrong ..
The provided .prj from you are really nice - but i guess in fact it does
not solve the problem.
I just wanted to know where the problem is to investigate it..
Are the .prj files wrong?
does gdal/ogr something strange?
is qgis acting wrong?
so wheres the real problem behind this all?
thx for your hints
regards
Werner
> Hello,
> I had also problems with ESRI-generated .prj - Files for Austria (in my
> case M31) - I solved it by manually editing the .prj - File respectively
> using those I have attached...
> See also the following page: http://www.alectoria.at/content/view/17/1/
> HTH,
> Albin
