[Qgis-user] Editing attributes
Kurt Springs
ferret_bard at mac.com
Thu May 14 12:56:51 PDT 2009
It started life as an ascii file I created in Barebone Textwrangler.
I imported it into GRASS using v.in.ascii to create point vectors,
hence the extra code. I just need a way to clean up the unnecessary
code to create labels for my maps I intend to put in my dissertation.
Kurt
On May 13, 2009, at 2:00 AM, Andreas Neumann wrote:
> Hi Kurt,
> What data format is your attribute data currently in? GRASS? Shape?
> Postgis?
> Depending on the data format there may be different option, as QGIS
> currently only allows manual editing of attributes, rather than
> automated
> commands/formulas as in spreadsheets or databases.
> If the data is in Postgis, I would use the replace() command in
> Postgis,
> if it is in a shapefile, you can use OpenOffice to edit the dbf file.
> Andreas
> On Tue, May 12, 2009 11:11 pm, Kurt Springs wrote:
>> I am trying to label certain sites. I originally used ascii files to
>> put the sites into GRASS. However, this leaves some ascii codes in
>> the labels in Qgis.
>> For example, the label comes out: #1 %51 @"Cat. 51". All I need is
>> Cat. 51 to appear on the map. This is in column str_1. The "toggle
>> editing mode" button is grayed out. How can I edit this column?
>> Thanks for any help.
>> Kurt
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
