[Qgis-user] Ubuntu version of QGIS - some crashes and bugs
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Sat May 9 09:16:21 EDT 2009
Hello again
I decided to uninstall and follow Giovanni's compilation guide (very
nice guide by the way). Compiled qgis 1.0.2 (rev 10759) and now the
symbology crash issue is finally gone.
Concerning the slow print composer, the problem remains. Can anyone
offer some insight on this?
The problem is, whenever I add a map a new map in the print composer,
after selecting the maps dimensions, qgis takes more than a minute
(maybe more than two minutes) to respond. After that, if I try to
update the map the same lag happens. If I add other stuff to the map
(scale, legend, ...) it displays normally.
Thank you
On Sat, May 9, 2009 at 11:37 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
> This problem does not occur with Ubuntu 8.04,
> I'll add a note to the ticket for clarification.
> Agus
> Giovanni Manghi wrote:
>>> xperiencing some troubles, not present before:
>>> - The symbology options crash Qgis whenever I am using floating point
>>> attributes and graduated symbols. I filled a ticket about this (ticket
>>> #1679) with more information and a test vector file. This is a major
>>> bug for me as it is impairing my visualization process.
>> Noticed also by me,
>> every time you try to classify using an attribute that is "real" and not
>> "integer", qgis crashes, no matter how simple is the attribute table.
>> Tested on qgis 1.0.1 and Ubuntu 8.10.
>> -- Giovanni --
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
___________________________ ___ __
Ricardo Garcia Silva
