[Qgis-user] ManageR: load ASCII grid file
Carson Farmer
carson.farmer at gmail.com
Thu Oct 15 04:41:43 PDT 2009
Hi enrico,
Based on the fact that it works ok for vector layers, I would guess that the
error message you are getting is simply wrong (my bad :-()
Would it be possible for you to send me the ASCII grid layer to test?
Some background: manageR actually uses the rgdal package to import raster
data (it's faster, and QGIS doesn't *yet* have the
facilities to operate on rasters properly), so it's possible that this is an
gdal error...
Regards,
Carson
On Thu, Oct 15, 2009 at 10:13 AM, enrico chiaradia <
enrico.chiaradia at unimi.it> wrote:
> Hi,
> I'm playing with ManageR (I hope to work with it in the future!) and I meet
> this problem:
> I can't import ASCII grid layer from canvans (CTRL+L) because it says to me
> that:
> "manageR import function
> Error: Unable to find R package 'sp'.
> Please manually install the 'sp' package in R via install.packages()"
> Ok, I looked for installed packages and 'sp' seems correctly installed!
> > installed.packages()
> Package LibPath Version
> rgdal "rgdal" "C:/Programmi/R/R-2.9.2/library" "0.6-14"
> rpart "rpart" "C:/Programmi/R/R-2.9.2/library" "3.1-45"
> sp "sp" "C:/Programmi/R/R-2.9.2/library" "0.9-43"
> spatial "spatial" "C:/Programmi/R/R-2.9.2/library" "7.2-48"
> splines "splines" "C:/Programmi/R/R-2.9.2/library" "2.9.2"
> stats "stats" "C:/Programmi/R/R-2.9.2/library" "2.9.2"
> stats4 "stats4" "C:/Programmi/R/R-2.9.2/library" "2.9.2"
> Any ideas to resolve this issue?
> BTW: it works perfectly with vector file and attribute table!
> enrico
> Qgis-user mailing list
Carson Farmer
National Centre for Geocomputation
John Hume Building,
National University of Ireland, Maynooth,
Maynooth,
Co. Kildare,
Ireland.
www.carsonfarmer.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091015/7da6de47/attachment.html>
