[Qgis-user] manageR plugin
Carson Farmer
carson.farmer at gmail.com
Thu Oct 29 04:04:08 PDT 2009
Hmmm, Rpy2 should support all versions of R barring any major changes.
I'm running R 2.10.0 on my machine with manageR working nicely...
@marco zanieri: This is a common problem with R for windows... all you
should have to do is add your R.exe (RHOME, or R install path) to your
path environment variable.
See here for more info/help:
http://cran.r-project.org/bin/windows/base/rw-FAQ.html#Does-R-use-the-Registry_003f
http://vlaurie.com/computers2/Articles/environment.htm
Cheers,
Carson
On Thu, Oct 29, 2009 at 9:27 AM, Anne Ghisla <a.ghisla at gmail.com> wrote:
> On Thu, 2009-10-29 at 08:54 +0100, marcozanieri at geosweb.it wrote:
>> Hi, I'm trying to use "manageR" plugin on Qgis 1.3Mimas for
>> winxp, before i installed R 2.10, after installed the plugin
>> "manageR", but it doesn't work, the python errore message is
>> the follow:
>> Traceback (most recent call last):
>> import rpy2.rinterface as rinterface
>> File "C:/Programmi/Quantum GIS
>> Mimas/./python\rpy2\rinterface\__init__.py", line 22, in
>> "This might be because R.exe is nowhere in your Path.")
>> RuntimeError: Unable to determine R version from the
>> registery.Calling the command 'R RHOME' does not return
>> anything.
>> Versione Python:
>> 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit
>> (Intel)]
>> Sentiero Python:['C:/Programmi/Quantum GIS Mimas/./python',
>> Anybody knows the solution??
> I'm afraid that R 2.10 is not yet supported by rpy2 [1], better
> downgrading to 2.9.
> Enjoy manageR!
> Anne
>> thanks all
>> marco zanieri
>> ______________
> [1] http://rpy.sourceforge.net/rpy2/doc/html/overview.html#installation
> Qgis-user mailing list
Carson Farmer
National Centre for Geocomputation
John Hume Building,
National University of Ireland, Maynooth,
Maynooth,
Co. Kildare,
Ireland.
www.carsonfarmer.com
