[Qgis-user] Save Paths Relative to the .qgs project file
Jürgen E. Fischer jef at norbit.de
Fri Sep 4 12:41:31 PDT 2009
Hi Greg,
On Fri, 04. Sep 2009 at 13:13:08 -0400, Greg Coats wrote:
> The 1 June 2009 posting to https://trac.osgeo.org/qgis/ticket/1211
> indicated that a request posted a year ago for QGIS to support Save
> Relative Paths had been fulfilled.
This only works when your data is below the project file.  In that case the
path to the project file is stripped from the data file, ie. if your project
/foo/bar.qgs your data must also in /foo or some subdirectory of it.
But I'm currently working on that...
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
