[Qgis-user] PRoblem installing python-qgis-common (1.2.0-1~hardy2)
Rainer M Krug r.m.krug at gmail.com
Mon Sep 7 00:45:32 PDT 2009
Hi
I get the following error message when I try to install
python-qgis-common (1.2.0-1~hardy2), but QGIS 1.2.0 is running without
problems, even the python plugins.
Any idea what is causing this?
Cheers,
Rainer
Setting up python-qgis-common (1.2.0-1~hardy2) ...
Compiling /usr/share/qgis/python/plugins/plugin_installer/ui_qgsplugininstallerbase.py
  File "/usr/share/qgis/python/plugins/plugin_installer/ui_qgsplugininstallerbase.py",
line 16
    QgsPluginInstallerDialogBase.setWindowIcon(QtGui.QIcon("
SyntaxError: EOL while scanning single-quoted string
pycentral: pycentral pkginstall: error byte-compiling files (88)
dpkg: error processing python-qgis-common (--configure):
 subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
 python-qgis-common
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install.  Trying to recover:
line 16
Rainer M. Krug, Centre of Excellence for Invasion Biology,
Stellenbosch University, South Africa
