[Qgis-user] Overlay request
Jacolin Yves
yjacolin at free.fr
Tue Sep 8 03:12:54 PDT 2009
Le Tuesday 08 September 2009 11:43:19 Alex Mandel, vous avez écrit :
> Jacolin Yves wrote:
> > Le Tuesday 08 September 2009 10:58:57 Jacolin Yves, vous avez écrit :
> >> Hello,
> >> Is it possible to do an overlay request on two layers in QGIS?
> >> I would like to get a new layer showing features of layer A overlaying
> >> features of layer B.
> >> thanks,
> >> Y.
> > One information: my layers are not in a postgis layer and I would like to
> > avoid to import them (yes I am lazy :p )
> > Does fTools will add such feature?
> > Y.
> Yes Clip should do what you want, it can also be achieved via an
> intersect, although that will merge the attribute tables in the overlap
> and possibly cut polygons.
> I wrote a modification to the old geoprocessing tool called an extract
> which is very similar but is a select by overlap instead of a cut. It's
> very similar to v.extract in grass. I can post if that's what you need
> and maybe we can get Carson to add it to ftools.
> Alex
> Qgis-user mailing list
Hello,
Thans Alex but I don't think it is what I want.
Actualy I would like to do select feature overlapping another layer. See
picture : http://img171.imageshack.us/i/qgisclip.jpg/
I want to get feature inside blue polygon, see the one at the top left with
some part outside the picture :/
This is not a geotreatment, just a spatial select.
In postigs I can do it with something like :
SELECT f.* FROM layer1 AS f, layer2 AS l WHERE
ST_Overlaps(f.the_geom,l.the_geom)=true
I tried to use "spatial select" in fTools (search tools>spatial select I am
not sure of the title in english as my GUI is in french) but it fails with an
error message.
Regards,
Y.
Yves Jacolin
Ne demandez pas si vous pouvez contribuer, contribuez ! :)
http://softlibre.gloobe.org
