[Qgis-user] Python Batch Processing
Agustin Lobo
alobolistas at gmail.com
Thu Sep 10 07:17:49 PDT 2009
Mauricio,
how should we use it?
I've unzipped under .qgis/python/plugins
but the get an error upon qgis start up:
Couldn't load plugin "pybatchproc" from ['/usr/share/qgis/python',
'/home/alobo/.qgis//python/plugins/symbology_ng',
'/home/alobo/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
'/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
'/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
'/usr/lib/python2.6/dist-packages/Numeric',
'/usr/lib/python2.6/dist-packages/PIL',
'/usr/lib/python2.6/dist-packages/gst-0.10',
'/var/lib/python-support/python2.6',
'/usr/lib/python2.6/dist-packages/gtk-2.0',
'/var/lib/python-support/python2.6/gtk-2.0',
'/usr/local/lib/python2.6/dist-packages',
'/usr/share/qgis/python/plugins/fTools/tools', '~/.qgis/python',
'/usr/share/qgis/python/', '/usr/share/qgis/python/',
'/usr/share/qgis/python']
File "", line 2, in
ImportError: No module named pybatchproc
Python version:
2.6.2 (release26-maint, Apr 19 2009, 02:11:59)
[GCC 4.3.3]
Agus
MaurĂcio de Paulo wrote:
> Hi list,
> As I am a serious user of GDAL Utilities and FWTools, I've found
> myself manytimes trying to repeat a ogr2gr or a gdalwarp for whole
> directories and writing much bash and bat code for the task. As a
> solution the the guys who work with me I've written the PyBatchProc
> script that is a QT gui to run command-line tools for series of files
> in folders or subfolders.
> I'm planning on creating a QGIS plugin script to let the tool run from
> inside QGIS too.
> https://sourceforge.net/projects/pybatchproc/files/pybatchproc_0_1.zip/download
> Any bugs found or sugestions are welcome.
> I hope you enjoy.
> MaurĂcio de Paulo
> Qgis-user mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090910/ef13969b/attachment.vcf>
