[Qgis-user] Python Batch Processing
Agustin Lobo alobolistas at gmail.com
Fri Sep 11 02:17:34 PDT 2009
Thanks Mauricio, installed.
You mentioned gdalutilites and FWT,
could you provide an example of using
a gdal utility (i.e. gdalbioldvrt or gdal_translate)
and a FWT utility through your plugin?
Agus
Maurício de Paulo wrote:
> Ok, as promised, it now works also as a qgis plugin.
> I've uploaded it in the contributed repository so everyone could download.
> I hope you guys enjoy it. :D
> Maurício de Paulo
> 2009/9/10 Maurício de Paulo <mauricio.dev at gmail.com
> <mailto:mauricio.dev at gmail.com>>
>     Ok, I havent started the pyqgis section yet. I was still working
>     saving parameters to commands.
>     I'm going to start this right now. It should be finished by the end
>     of this evening.
>     At the moment it only works standalone (just call it as a python
>     program).
>     Thanks for the interest
>     Maurício de Paulo
>     2009/9/10 Agustin Lobo <alobolistas at gmail.com
>     <mailto:alobolistas at gmail.com>>
>         Mauricio,
>         how should we use it?
>         I've unzipped under .qgis/python/plugins
>         but the get an error upon qgis start up:
>         Couldn't load plugin "pybatchproc" from
>         ['/usr/share/qgis/python',
>         '/home/alobo/.qgis//python/plugins/symbology_ng',
>         '/home/alobo/.qgis//python/plugins',
>         '/usr/share/qgis/python/plugins', '/usr/lib/python2.6',
>         '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
>         '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
>         '/usr/lib/python2.6/dist-packages',
>         '/usr/lib/python2.6/dist-packages/Numeric',
>         '/usr/lib/python2.6/dist-packages/PIL',
>         '/usr/lib/python2.6/dist-packages/gst-0.10',
>         '/var/lib/python-support/python2.6',
>         '/usr/lib/python2.6/dist-packages/gtk-2.0',
>         '/var/lib/python-support/python2.6/gtk-2.0',
>         '/usr/local/lib/python2.6/dist-packages',
>         '/usr/share/qgis/python/plugins/fTools/tools', '~/.qgis/python',
>         '/usr/share/qgis/python/', '/usr/share/qgis/python/',
>         '/usr/share/qgis/python']
>         Traceback (most recent call last):
>          File "", line 2, in
>         ImportError: No module named pybatchproc
>         Python version:
>         2.6.2 (release26-maint, Apr 19 2009, 02:11:59)
>         [GCC 4.3.3]
>         Agus
>             Hi list,
>             As I am a serious user of GDAL Utilities and FWTools, I've
>             found myself manytimes trying to repeat a ogr2gr or a
>             gdalwarp for whole directories and writing much bash and bat
>             code for the task. As a solution the the guys who work with
>             me I've written the PyBatchProc script that is a QT gui to
>             run command-line tools for series of files in folders or
>             subfolders.
>             I'm planning on creating a QGIS plugin script to let the
>             tool run from inside QGIS too.
>             https://sourceforge.net/projects/pybatchproc/files/pybatchproc_0_1.zip/download
>             Any bugs found or sugestions are welcome.
>             I hope you enjoy.
>             Maurício de Paulo
>             _______________________________________________
>             Qgis-user mailing list
>             Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/qgis-user
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090911/5cc57873/attachment.vcf>
