[Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not work]
Rainer M Krug r.m.krug at gmail.com
Fri Sep 11 06:38:11 PDT 2009
If I might add - I have the same problem under Hardy. Below my tests:
On Fri, Sep 11, 2009 at 2:45 PM, Jürgen E. <jef at norbit.de> wrote:
> On Fri, 11. Sep 2009 at 13:55:42 +0200, Agustin Lobo wrote:
>> In grass
>> r.in.gdal -o
>> input=/media/Transcend/ANYELLA/catuav20090730/tif/SDIM0178.tif
>> output=delmetif
> That's the wrong direction.    You need to access GRASS from GDAL not vice
> versa.
> gdalinfo $HOME/grass/spearfish60/PERMANENT/cellhd/elevation.10m
rkrug at ecolmod:~$ gdalinfo --version
GDAL 1.6.1, released 2009/05/11
/home/rkrug/grass/spearfish60/PERMANENT/cellhd/elevation.10m
Segmentation fault
rkrug at ecolmod:~$
>> $ sudo apt-get install qgis-plugin-grass
>> Reading package lists... Done
>> Building dependency tree      Reading state information... Done
>> The following extra packages will be installed:
>>  libgdal1-1.5.0 libgdal1-1.5.0-grass qgis-plugin-grass-common
>> The following NEW packages will be installed:
>> 0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
>> Need to get 0B/9986kB of archives.
>> After this operation, 19.4MB of additional disk space will be used.
>> Do you want to continue [Y/n]? n
>> Abort.
> That's strange.  Try
>  apt-cache rdepends libgdal1-1.5.0
> to see what depends on libgdal1-1.5.0.  There shouldn't be anything qgis or
> grass related except for libgdal1-1.5.0-grass.
> And try
>  apt-cache depends qgis-plugin-grass
rkrug at ecolmod:~$ apt-cache depends qgis-plugin-grass
qgis-plugin-grass
  Depends: libc6
  Depends: libgcc1
 |Depends: libgdal1-1.4.0-grass
 |Depends: <libgdal1-1.5.0-grass>
  Depends: libgdal1-1.6.0-grass
  Depends: libgeos-c1
  Depends: libproj0
  Depends: libqgis1.2.0
  Depends: libqt4-core
  Depends: libqt4-gui
  Depends: libqt4-sql
  Depends: libstdc++6
  Depends: qgis
  Depends: qgis-plugin-grass-common
> to see what qgis-plugin-grass depends on.  There should only be the dependency
> to one of the libgdal1-*-grass packages - and that should be satisfiable by
> installing libgdal1-1.6.0-grass.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
Rainer M. Krug, Centre of Excellence for Invasion Biology,
Stellenbosch University, South Africa
