[Qgis-user] decorations and graticule in print composer
Giovanni Manghi
giovanni.manghi at gmail.com
Fri Sep 18 09:45:42 PDT 2009
you can add the north arrow by adding it as an image.
If I'm not wrong one of the developers is working on adding the feature
to add grids in the print composer.
cheers
-- Giovanni --
On Fri, 2009-09-18 at 09:19 -0430, Eduardo Klein wrote:
> Hi,
> Is there a way to put north arrow and a graticule with coordinates in
> the map's border in the print composer?
> Saludos, EKS
