[Qgis-user] Value Tool Plug-in Problem
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue Sep 29 18:07:29 PDT 2009
On Wed, 2009-09-30 at 00:05 +0200, Borys Jurgiel wrote:
> Dnia wtorek, 29 września 2009 o 23:55:30 pabloaz napisał(a):
> > Agus,
> > It seems "Scattergram" is doing the same thing as "Value Tool".
> So it seems it's another problem. You probably need the Qwt5 python module.
> > "Shaded Relief" and "Image Clipper" were invalid or with unfulfilled
> > dependencies, it seems they require other plugins (i.e. gdal and osgeo). I
> > couldn't find Osgeo.
> As above, you need to install the python-gdal module (the both 'gdal' and
> 'osgeo' names refer to the same module).
> Could any Mac Geek provide an instruction how to install python modules and
> publish it on the wiki? :)
An extra-question (for those working with latest osgeo code): is it
possible to install "python-gdal" under Ubuntu Jaunty 64-bit and
keep-out the libgdal1-1.5.0 package?
Nikos
