[Qgis-user] Image Cutter Plugin Release
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Sep 30 05:58:58 PDT 2009
On Wed, 2009-09-30 at 06:55 -0500, Bob Bruce wrote:
> I have just put the Image Cutter plugin to the repository:
> http://www.mappinggeek.ca/QGISPythonPlugins/Bobs-QGIS-plugins.xml. We
> use this plugin to extract image tiles from a QGIS Image Layer. I have
> only tested this on Windows so I'm not sure how other OSs will work with
> it. Feedback would be appreciated.
> Help on the plugin is available at:
> http://www.mappinggeek.ca/QGISPythonPlugins/image_cutter/indexInternet.html
> This plugin may be incorported at some point into the GDAL Tools plugin
> but I'm releasing here for the time being.
> thanks,
> Bob Bruce
Hi and thanks for one of the very wanted functionalities :-)
Under Ubuntu Jaunty 64-bit, QGIS 1.4.0-trunk, revision 11691 I get the
following message when trying to install Image Cutter:
The plugin is broken. Python said:
Bad magic number
in /home/nik/.qgis//python/plugins/image_cutter/resources.pyc
Nikos
