[Qgis-user] Problems with save as projection
Goyo goyodiaz at gmail.com
Fri Apr 2 11:32:36 PDT 2010
El jue, 01-04-2010 a las 00:17 +0200, jamesmikedupont at googlemail.com
escribió:
> Hi,
> I am also using 1.4 on karmic, the ubuntugis ppa.
> I did not set it, but saved as a new projection
> opened that and used the reproject tool.
> Will try with the set and save. Does that save as do the reprojection
> or just set it?
> mike
The "Save as" menu reproject the layer geometries.
But every tool will lead to wrong results if you do not set the correct
srs first.
The layer has a wrong .prj file so QGIS is wrong about the layer srs.
The first thing you have to do is tell QGIS what the correct srs is,
using the properties dialog. After that everything should work well.
Goyo
> On Wed, Mar 31, 2010 at 11:26 PM, Goyo <goyodiaz at gmail.com> wrote:
> > El mié, 31-03-2010 a las 16:04 +0200, jamesmikedupont at googlemail.com
> > escribió:
> >> Hi there,
> >> I wanted to report a bug :
> >> This file is falsly listed as EPSG:2466, but is it really EPSG:2641
> >> http://filebin.ca/hbvcyo/dragash.tgz
> > The bug is in the data, the .proj file wrongly says EPSG:2466.
> >> I cannot save it as 2641 in qgis and then convert it to EPSG:4326.
> >> There is no way i found to process this file in qgis,
> > Using QGIS 1.4.0 in Ubuntu Karmic I was able to open the shapefile, set
> > the layer SRS to EPSG:2641 ans save it as EPSG:4326.
> > Goyo
