[Qgis-user] Complete information of a point created automatically.
Goyo goyodiaz at gmail.com
Wed Apr 7 15:58:29 PDT 2010
El mié, 07-04-2010 a las 12:02 +0200, Patrice Vetsel escribió:
> I want to use Qgis in situation on the ground. Using a plugin to center
> a map dynamically connected to my gps. My problem is that the creation
> of points on a shapefile layer is very restrictive if you want to fill
> at the same time, the information (1500 points to be created). The idea
> is to have a configurable plugin, which will, after selecting a type,
> fill in items automatically.
> The information is rather repetitive and rather simple. These are street
> lights and often they are the same. Power, nature of bulbs, I'd have to
> input every time. The best would be that the ID is automatically
> incremented and I can select a type (Power 100W/Nature Sodium). After
> selection by clicking on the map to add as many points as you want, and
> the ID field is incremented and power / 100W/Sodium nature are made.
> Have you any ideas?
You can use custom forms (and maybe python):
http://linfiniti.com/2009/11/creating-dynamic-forms-a-new-feature-headed-for-qgis-1-4/
Also postgis allows you to set default and autoincremental values. Read
this recent thread.
http://www.mail-archive.com/qgis-user@lists.osgeo.org/msg05777.html
