[Qgis-user] GSSAPI Support under OSX
Garbin, David
david.garbin at noblis.org
Thu Apr 8 09:08:57 PDT 2010
Thanks much, William! Your latest build of Postgres with the new libpq
library has solved all my problems. I replaced the original libpq.dylib
in both the QGIS and pgAdmin3 packages with your library and aliases and
both of those applications now work perfectly using Kerberos to
authenticate with our Postgres server.
David A. Garbin
Senior Fellow
Noblis
3150 Fairview Park Dr S
Falls Church, VA 22042
Phone: +1 703.610.2050
Cell: +1 703.795.6010
Email: david.garbin at noblis.org
-----Original Message-----
From: William Kyngesburye [mailto:woklist at kyngchaos.com]
Sent: Wednesday, April 07, 2010 9:54 AM
To: Garbin, David
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] GSSAPI Support under OSX
Qgis and pgadmin3 use separate copies of libpq, but you are still
probably right. I know I don't build my Postgres GSSAPI - it doesn't
appear to be a default-on configure option, and I never bothered to look
into what it is. Very likely whoever built the Mac version of pgadmin3
did the same with their libpq.
I do include Kerberos, which appears to be related. I could easily add
GSSAPI in my next Postgres build (I see 8.4.3 is out, so it should be
soon), though it will probably only appear in my Qgis dev builds and not
1.4.
On Apr 7, 2010, at 7:37 AM, Garbin, David wrote:
> I am trying to access a PostgreSQL 8.4 database on a remote LINUX
server with Kerberos 5 tickets using GSSAPI. This works from a Windows
version of QGIS , but the OSX binary version gives a "GSSAPI
Authentication not supported" error. A binary download of pgamin3 also
gives the same error, so I suspect a common libpq problem. GSSAPI
authentication is working fine for SSH clients on the same machine.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between my
immediate physical sensations and my state of mind?"
- The Ruler of the Universe
