[Qgis-user] Python error - InfoTool plugin
Volkan Kepoglu vkepoglu at gmail.com
Mon Apr 12 07:09:42 PDT 2010
thanks. the error should be fixed with this new revision, even it is
installed under /usr.
On Fri, Apr 9, 2010 at 3:16 PM, Borys Jurgiel <borysiasty at aster.pl> wrote:
> Dnia piątek, 9 kwietnia 2010 o 13:40:48 Vasile Cristian Stan napisał(a):
> > Hi all,
> > I have this problem with qGis when i try to activate InfoTool plugin
> > IOError: [Errno 13] Permission denied:
> > '/usr/share/qgis/python/plugins/infotool/logFile.log'
> > Any ideeas?
> I'm quite surprised all your plugins are in the /usr directory. Is it
> intentional they're not in your home directory? If not, how did you install
> them - using Plugin installer (Plugins->Fetch plugins) or manually?
> Qgis-user mailing list
>  http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100412/e4f8b15e/attachment.html>
