[Qgis-user] Question about GDAL tools in QGIS 1.4
Giovanni Manghi giovanni.manghi at gmail.com
Thu Apr 15 04:24:52 PDT 2010
On Thu, 2010-04-15 at 13:14 +0200, Lassche, M.R (Ronnie) wrote:
> Giovanni,
> Thanks, it did the job.
fine.
If you use windows Vista/Seven and you'll get problems/errors using the
gdal tools plugin, then you'll need to:
*) use the "dev" version of qgis that you can install with the osgeo4w
installer
*) delete the %SOGEO4W_ROOT%\apps\gdal-16\bin\gdalplugins\gdal_GRASS.dll
file
cheers
-- Giovanni --
