[Qgis-user] averaging raster grid
M.E.Dodd m.e.dodd at open.ac.uk
Thu Apr 15 07:22:26 PDT 2010
The projection systems all seem to be wgs84.  However I must be something basic wrong when trying to get the vector layer in, how should you do this?  I have the vector layer either as a shapefile sitting on the hard disk or an opened shapefile in qgis, suspect there is something wrong with how it gets put into the mapset/gridbase etc in grass as I am not use to doing things this way.
-----Original Message-----
Sent: 15 April 2010 14:15
To: M.E.Dodd
Cc: 'qgis-user at lists.osgeo.org'
Subject: Re: [Qgis-user] averaging raster grid
On 15/04/2010 15:43, M.E.Dodd wrote:
> http://www.amanita-photolibrary.co.uk/Untitled-2.png
> humm, there does not seem to be any data there
Hummm, indeed. So nothing got imported. Can you just verify that there's
no Coordinate system mismatch? (i.e. do you have "on the fly" projection
enabled?)
I saw in the previous image that the GRASS region was set OK, so that's
not the problem.
Perhaps try importing a simpler shapefile, european country boundaries
for example, from the naturalearthdata.com datasets, just to verify that
the procedure works?
> From: Micha Silver [mailto:micha at arava.co.il]
> Sent: 15 April 2010 12:05
> To: M.E.Dodd
> What I was hoping to see was something like this:
> http://www.surfaces.co.il/wp-content/uploads/2010/04/GrassToolbox.png
> Here we can determine how many features, what spatial extent.... Maybe
> that will give a hint why you're not seeing anything. Seeing this table
> for one of the rasters and the empty vector might be of help.
Micha Silver
Arava Development Co.  +972-52-3665918
The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302).
