[Qgis-user] grass module: r.water.outlet
Micha Silver micha at arava.co.il
Fri Apr 23 02:14:18 PDT 2010
julie rauw wrote:
> Hi
> I 'd like to use the r.water.outlet to outline watersheds. I inputed a
> flow direction map and the coordinates (Belgium Lambert 72) of the
> outlet . This direction map is from an elevation map made by the
> r.watershed fonction. But it doesn't work. Can you please help me
> about this? Thanks in advance.
Can you be more specific. What doesn't work? what result do you get?
Be aware that the outlet point must lie *exactly* on a stream. It's best
to display the stream layer you got from r.watershed, and choose X-Y for
the outlet drainage point by viewing the coordinates in the status bar.
> Julie Rauw
> Windows 7: vous aide à faire plus. Découvrez Windows 7.
> <http://windows.microsoft.com/fr-BE/windows7/products/home?os=win7>
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
