AW: [Qgis-user] Compile problem?
Möri Cedric Cedric.Moeri at bd.so.ch
Wed Aug 4 04:00:58 PDT 2010
Hi Jürgen
in /usr/local/foo/lib are also libs from a former 1.5.0. On the same machine are also two other installations of qgis (r13851) both also with prefixes. They work properly. So yes, there is stuff from other/older installations. Is that what you mean? Any idea how to identfiy the 'bad' libs or headers?
regards/beste Grüsse
Cédric
mit freundlichen Grüssen
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon: +41 (0)32 627 24 75
Telefax: +41 (0)32 627 22 14
mailto:cedric.moeri at bd.so.ch
http://www.agi.so.ch
----- Originalnachricht -----
Von: "Jürgen E. Fischer" <jef at norbit.de>
Gesendet: Mit, 4.8.2010 12:36
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Compile problem?
Hi Cédric,
On Wed, 04. Aug 2010 at 12:19:31 +0200, Möri Cedric wrote:
> I just compiled r14004 on RedHat-Linux. Everything seems to go fine, but when
> I now start the new qgis, it says
> Warning: Couldn't load Python support library: Cannot load library
> /lib/qgispython: (/lib/libqgispython.so: Kann die Shared-Object-Datei nicht
> öffnen: Datei oder Verzeichnis nicht gefunden) (the german reads: Cannot open
> shared object file: File or directory not found)
Do you have old QGIS libraries or headers around?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
