[Qgis-user] Re: Installing QGIS 1.5 on Debian Squeeze
Gary Smith gary.smith.rsa at gmail.com
Wed Aug 4 11:35:04 PDT 2010
Niccolo,
A further update.
Immediately after sending the previous mail I realised that the
installed version was not Tethys. It seems that the Lenny & Squeeze
repositories on http://debian.gfoss.it/ are not synchronised.
I cannot select the Lenny repository with a standard sources.list file
as Synaptic gives preference to the version 1.4.0 in the Debian Squeeze
repository.
So I temporarily disabled the Debian repository in the sources.list file
and enabled the gfossit repository as follows:
#deb ftp://ftp.is.co.za/debian testing main contrib non-free
#deb http://security.debian.org testing/updates main contrib non-free
deb http://debian.gfoss.it/ lenny main
I purged the prior qgis installation and reinstalled. Now it is Tethys
again. I still have the crash that I reported yesterday at the same
point of loading but it is now *not a segmentation fault *- see below:
AspireOne:/home/gary# qgis
Warning: Qt: Session management error: None of the authentication
protocols specified are supported
Regards
Gary
On 04/08/2010 12:22, Niccolo Rigacci wrote:
> On Tue, Aug 03, 2010 at 07:25:01PM +0200, Gary Smith wrote:
>> Nicollo,
>> I get a segmentation fault. This occurs immediately the "Starting
>> Python" message is displayed on the Splash screen.
>> Also, there also appears to be a dependency problem with the grass plugin.
> Check all the old packages/libraries you have installed and
> remove them manually:
> dpk --list | grep qgis
> dpkg --purge<package_name>  <package_name>  ...
> Then re-do the apt-get install.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100804/12f5963a/attachment.html>
