Res: [Qgis-user] management tables
Borys Jurgiel borysiasty at gmail.com
Wed Aug 4 13:16:39 PDT 2010
Dnia środa 04 sierpnia 2010 o 16:05:07 Giovanni Manghi napisał(a):
> Hi Dario,
> please keep the conversation on-list, it can be useful to others.
> On Wed, 2010-08-04 at 07:00 -0700, Dario wrote:
> > mean the following:
> > a field where you can insert a hyperlink to a picture or pdf or doc.
> > For example, to view a photo of a building.
> > Just as is done in gvSIG or KOSMOS
> try the edit widgets, especially the "file name" one. You find the
> widgets in the vector properties, attributes panel.
You can be also interested in setting an action on desired field. The action
could e.g. call image or pdf browser. Look in layer properties.
