[Qgis-user] Qgis file (*.qgs) > Mapnik (*.xml) > OSM file (*.osm) > PostGIS > GeoServer ?
Noli Sicad nsicad at gmail.com
Thu Aug 5 22:05:21 PDT 2010
Hi Maning,
Thanks for the clarification.
So, osm file (*.osm) is just data and the styling and rendering are
done in OSM webserver using Mapnik render and SLD.
I was thinking that osm2pgsql also dump the styling rule as inside the OSM file.
http://demo.opengeo.org/openstreetmap/
So, What I need is SLD in QGIS. SLD is QGIS 2.0 roadmap :)
Thanks.
Noli
On 8/6/10, maning sambale <emmanuel.sambale at gmail.com> wrote:
>> 2. Mapnik (*. xml) to OSM file (*.OSM).
>> How do you export / save mapnik. xml to OSM file format (*.osm)?
>> Is this possible?
> Mapnik xml is a styling configuration file (i. e, SLD, QML)  .osm is a
> data format (i. e. shapefile).
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
