[Qgis-user] convert the area from 1 sq degrees to hectare
Micha Silver micha at arava.co.il
Sat Aug 7 04:02:09 PDT 2010
On 08/07/2010 11:31 AM, herman palaquium wrote:
> glad to see you again
> as you know that my places at N-E of the year ( please type buol
> indonesia on the google maps) I STAY THERE
> i remember that you give me the answer before, but CAN YOU GIVE
> FORMULA HOW TO CONVERT 1 SQ DEG. TO ...... HECTARE ..?
You can *not* just convert degrees to hectares in a Lon/Lat projection.
The rough figures I sent last time were just an inaccurate estimate.
Afterall, as you move north or south towards the poles, the width of 1
degree changes in size.
What you should do is re-project your data to some projected coordinate
reference system. Then units will then most likely be in meters, and you
can calculate areas very simply. I see [1] that Indonesia uses a set of
Transverse Mercator projections. You might chose the one relevant to
your area.
In QGIS:
* you can project a shapefile to another CRS by using the "Save As"
option, and select whatever export CRS you want.
* Rasters can be re-projected using the Raster Tools plugin, gdalwarp tool.
[1]  http://www.spatialreference.org/ref/?search=indonesia
Micha
> PLEASE STEP BY STEP FORMULA YOU TYPE IT, FOR I KNOW THE WAY OF FORMULA
> FUNCTION
> I HOPE GREATEST THAT KNOW FOR MY STUDY
> SALAM HORMAT
> HERMAN DARI INDONESIA
> On 27 Jun 10, at 0:47, Nicklas Avén wrote:
>> Hallo
>> hmm, is this right Micha. Isn't the size of a sqare degree depending
>> on how far from equator it is. Since the vertical longitudes are
>> convergating to the poles 1 west-east degree is 0 at the pole and
>> about 40000/360 km at the equator which makes the conversion difficult.
>> /Nicklas
>> ----- Ursprungsmeddelande -----
>> > On 06/26/2010 03:40 PM, herman palaquium wrote:
>> > > AREA: 2.7e-05
>> > > KebunPoly: KebunAmran1
>> > > Luas: 0
>> > > PERIMETER: 0.024863
>> > > Panjang: 0
>> > > please help the area and perimeter unit
>> > The numbers above indicate area: 0.000027 square units.
>> > If, by mistake, you projection units is degrees, instead of meters,
>> then
>> > this would be 0.000027 square degrees. One sq deg ~= 110 km X 110
>> km, or
>> > about 12,000 sq km. So the above would translate to approximately
>> > 327,000 sq meters. Does that make more sense?
>> > Again, if your units are degrees, not meters, then the perimeter would
>> > be around 2,730,000 meters. (110 km/deg X 0.2483 )
>> > > my projection is meter
>> > > where is the correct 2,4863 meter
>> > > or 24,863 meter
>> > > or 248,63 meter
>> > > or 2486,3 meter
>> > > or 24863 meter
>> > > or any answer the correct
>> > > and than
>> > > where is the correct area answer ?
>> > > 0,27 ha
>> > > 2,7 ha
>> > > 27 ha
>> > > 270 ha
>> > > herman
>> > > indonesia
>> > > _______________________________________________
>> > > Qgis-user mailing list
>> > > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > > This mail was received via Mail-SeCure System.
>> > Micha Silver
>> > Arava Development Co. +972-52-3665918
>> > http://www.surfaces.co.il
Micha Silver
http://surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100807/d2c733fb/attachment.html>
