[Qgis-user] Re: Couldn't import 'matplotlib'
Kurt Springs ferret_bard at mac.com
Sun Aug 8 12:41:34 PDT 2010
Thank's William
 I assumed it was either part of qgis or was a plugin itself.  I found a matplotlib package with google for OS 10.6 at http://www.cgl.ucsf.edu/Outreach/pc204/matplotlib.html.  It works now.
Again Thanks
Kurt
On Aug 8, 2010, at 3:13 PM, William Kyngesburye wrote:
> How did you install matplotlib?  Binaries from sourceforge are probably 32bit only.  If you are running Qgis on Snow Leopard, it will be running 64bit, unless you have one of the original core solo/duo Macs
> On Aug 8, 2010, at 1:27 PM, Kurt Springs wrote:
>> I installed William's update and am getting the same message when I start.  It's still useable.  I had this problem with 1.4 as well.
>> Kurt
>> On Aug 8, 2010, at 12:00 PM, qgis-user-request at lists.osgeo.org wrote:
>>> Hi,
>>> I am getting the following error message when I open qgis.  I am currently running Qgis 1.5 for Mac OS X.
>>> "Couldn't import Python module 'matplotlib' for plotting.  Without it you won't be able to run statist."
>>> I am just clicking Okay and getting on with my work.
>>> statist is present but not checked in the plugins manager.  I was wondering if there were a way to get the matplotlib imported so I would no longer get the message and some day use the plugins that require it.
>>> As always, any help is appreciated.
>>> Kurt Springs
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100808/597d8305/attachment.html>
