[Qgis-user] QGIS1.5 on Win (standalone installation): Problem with VRT
Benoit de Cabissole benoit at exigesa.com
Tue Aug 10 23:17:49 PDT 2010
Agus,
Please try the following:
(note the comments in the xml to help you see the changes)
<VRTDataset rasterXSize="3001" rasterYSize="2554">
  <SRS>PROJCS["WGS 84 / UTM zone 26N",GEOGCS["WGS
84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.2572235630016,AUTHORITY["EPSG","7030&quo
t;]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich&qu
ot;,0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG&quot
;,"4326"]],PROJECTION["Transverse_Mercator"],PARAMETER[&
quot;latitude_of_origin",0],PARAMETER["central_meridian",-27]
,PARAMETER["scale_factor",0.9996],PARAMETER["false_easting&qu
ot;,500000],PARAMETER["false_northing",0],UNIT["metre",1
,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG",&q
uot;32626"]]</SRS>
  <GeoTransform> 6.5222487132554676e+005, 4.0000000000000000e+000,
0.0000000000000000e+000, 4.1899966827195832e+006,
0.0000000000000000e+000,-4.0000000000000000e+000</GeoTransform>
  <VRTRasterBand dataType="UInt16" band="1">
    <ColorInterp>Gray</ColorInterp>
    <SimpleSource>
      <SourceFilename
relativeToVRT="1">po_172227_blu_0000000.tif</SourceFilename>
      <SourceBand>1</SourceBand>
      <SourceProperties RasterXSize="3001" RasterYSize="2554"
DataType="UInt16" BlockXSize="3001" BlockYSize="256"/>
      <SrcRect xOff="0" yOff="0" xSize="3001" ySize="2554"/>
      <DstRect xOff="0" yOff="0" xSize="3001" ySize="2554"/>
    </SimpleSource>
<!-- added following two lines -->
  </VRTRasterBand>
  <VRTRasterBand dataType="UInt16" band="2">
    <SimpleSource>
      <SourceFilename
relativeToVRT="1">po_172227_grn_0000000.tif</SourceFilename>     <!--
changed relativeToVRT to 1 -->
    </SimpleSource>
  </VRTRasterBand>
  <VRTRasterBand dataType="UInt16" band="3">
    <SimpleSource>
      <SourceFilename
relativeToVRT="1">po_172227_nir_0000000.tif</SourceFilename>     <!--
    </SimpleSource>
  </VRTRasterBand>
  <VRTRasterBand dataType="UInt16" band="4">
    <SimpleSource>
      <SourceFilename
relativeToVRT="1">po_172227_red_0000000.tif</SourceFilename>     <!--
    </SimpleSource>
  </VRTRasterBand>
</VRTDataset>
This should hopefully do it.
Otherwise, is your data type really UInt16, can it be coerced to bytes?
Cheers,
Benoit
> -----Original Message-----
> From: Agustin Lobo [mailto:alobolistas at gmail.com]
> Sent: Tuesday, 10 August 2010 22:37
> To: Benoit EXIGE
> Cc: qgis-user; arturgil at gmail.com; cavallini at faunalia.it
> Subject: Re: [Qgis-user] QGIS1.5 on Win (standalone installation):
> Problem with VRT
> Thanks, I've done as below and the problem remains.
> Should I fill a ticket?
> 84",6378137,298.2572235630016,AUTHORITY["EPSG",&quo
> t;7030"]],AUTHORITY["EPSG","6326"]],PRIME
> M["Greenwich",0],UNIT["degree",0.0174532925199
> 433],AUTHORITY["EPSG","4326"]],PROJECTION[&quo
t;Transverse_Mercator"],PARAMETER>
["latitude_of_origin",0],PARAMETER["central_meridia
> n",-27],PARAMETER["scale_factor",0.9996],PARAMETER[
"false_easting",500000],PARAMETER>
["false_northing",0],UNIT["metre",1,AUTHORITY[
"EPSG","9001>
"]],AUTHORITY["EPSG","32626"]]</SRS>
>     <SimpleSource>
>       <SourceFilename
>     </SimpleSource>
>     <SimpleSource>
>       <SourceFilename
> relativeToVRT="2">po_172227_grn_0000000.tif</SourceFilename>
>     </SimpleSource>
>     <SimpleSource>
>       <SourceFilename
> relativeToVRT="3">po_172227_nir_0000000.tif</SourceFilename>
>     </SimpleSource>
>     <SimpleSource>
>       <SourceFilename
> relativeToVRT="4">po_172227_red_0000000.tif</SourceFilename>
>     </SimpleSource>
>   </VRTRasterBand>
> </VRTDataset>
> 2010/8/10 Benoit EXIGE <benoit at exigesa.com>:
> > Hi Agus,
> > Looks to me that the <sourceband> should be incremented from 1
> to 4 for your
> > four rasters.
> > Hope this helps.
> > Benoit
> > Sent from my iPod
> > On 10 Aug 2010, at 21:01, Agustin Lobo <alobolistas at gmail.com> wrote:
> >> Hi!
> >> I use the gdal utilities (raster/Build Virtual Raster) with 4 files but
> >> then QGIS sees one band only (only one band listed in the Properties
> >> dialog).
> >> This is the VRT file, could anyone tell me if this is correct?
"EPSG","9001>
> >>   <SimpleSource>
> >>     <SourceFilename
> >>   </SimpleSource>
> >>   <SimpleSource>
> >>     <SourceFilename
> >>   </SimpleSource>
> >>   <SimpleSource>
> >>     <SourceFilename
> >>   </SimpleSource>
> >>   <SimpleSource>
> >>     <SourceFilename
> >>   </SimpleSource>
> >>  </VRTRasterBand>
> >> </VRTDataset>
> >> Thanks
> >> Agus
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
