[Qgis-user] typing coordinates
Horst Düster horst.duester at kappasys.ch
Fri Aug 20 23:43:56 PDT 2010
The example of the second option would not work, because no attributes
are defined. Better to try:
select geometryfromtext ('POLYGON ((1 1, 2 2, 3 3, 1 1))',-1), 1 as id;
Regrads
Horst
Am 20.08.2010 20:49, schrieb Möri Cedric:
> Hi  Dario
> You're right, Numerical Vertex Edit is just to adjust the coords of a geometry. As a (quiet silly) workaround you may create a polygon with the exact number of vertices and then adjust them.
> Or you may use the "Postgis SQL Query Editor"-Plugin and then do something like
> maybe (no, for sure) there also better solutions.
> regards
> mit freundlichen Grüssen
> Cédric Möri
> GIS-Informatiker
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> Rötistrasse 4
> 4501 Solothurn
> Telefon: +41 (0)32 627 24 75
> Telefax: +41 (0)32 627 22 14
> mailto:cedric.moeri at bd.so.ch
> http://www.agi.so.ch
> ----- Originalnachricht -----
> Von: Dario<darioqn at yahoo.com.br>
> Gesendet: Fre, 20.8.2010 17:01
> An: qgis-user at lists.osgeo.org
> Cc: qgis-user-request at lists.osgeo.org
> Betreff: [Qgis-user] typing coordinates
> how to draw a polygon by typing x, y coordinates?
> through the prompt, without having to import files.
> PS:
> through numerical vertex edit plugin is not possible.
>         _______________________________________________
> Qgis-user mailing list
