[Qgis-user] Shapefile structure viewer and editor plugin
Benoit de Cabissole benoit at exigesa.com
Thu Aug 26 02:12:47 PDT 2010
So be it!
I've added it to the QGIS contributed repo and marked it as experimental.
Its ID is: "Shapefile Structure Viewer and Editor"
Cheers,
Benoit
> -----Original Message-----
> From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
> Sent: Thursday, 26 August 2010 10:52
> To: benoit at exigesa.com
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Shapefile structure viewer and editor plugin
> > BUT, I feel it is a quite dangerous plugin to release in a public repo
> > because of the potential damages bad edits can do on a shapefile!
> > I would thus be very grateful if the most intrepid amongst you
> could test it
> > and give comments on its usefulness...
> I can't see any problem by contributing it in the QGIS repositories...
> maybe tagging it as experimental and adding a warning message when it
> starts :)
> cheers
> -- Giovanni --
