[Qgis-user] RE: Shapefile structure viewer and editor plugin
Benoit de Cabissole
benoit at exigesa.com
Thu Aug 26 11:26:12 PDT 2010
Maxim,
Thanks for the suggestions.
I will work toward implementing them in the next couple of weeks, depending on other priorities.
I've also noticed the row height problem, I'm using default Qt settings, so, some tweaking is required...
Cheers,
Benoit
> -----Original Message-----
> From: Maxim Dubinin [mailto:sim at gis-lab.info]
> Sent: Thursday, 26 August 2010 19:16
> To: Benoit de Cabissole
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] RE: Shapefile structure viewer and editor
> plugin
> Benoit,
> thanks for very useful plugin, I've started developing something like
> this sometime ago, glad I didn't go very far! My idea was to replicate
> Arcview GIS 'shape properties' tool that I missed a lot. Let me give
> several comment to consider adding to your plugin to make it even
> more useful (IMHO of course):
> 1. Please consider working (or showing) only selected feature(s).
> It is not of much
> use if there are many polygons with many vertexes, you have to scroll
> up&down a lot to find needed feature. I can still see that seeing
> everythig is useful when you're working with empty layer (adding
> features), but a switch 'show only selected feature(s)' would these
> both suggestions.
> 2. Is it possible to shrink row height? May be its Windows, but mine
> are extra inflated occupying valuable space. Check this
> screenshot [1] (first two rows I shrank
> manually)
> 3. It would be really nice if node selected in the table would
> highlight in map canvas, thus allowing us to track were are they
> exactly.
> 4. I think 'close' button and little graphic on the left are
> unnecessary. I'd add current layer name and its type right in the window
> title.
> 5. It would be nice to able to delete a node(s) as well.
> 6. Please consider moving 'start|stop editing' functionality to QGIS
> itself, so that you'd have to start and stop editing in QGIS, I think
> it will be more straightforward.
> Thanks again,
> Maxim
> [1] http://gis-lab.info/images/screenshots/20100826-e65-51kb.jpg
> Вы писали 26 августа 2010 г., 3:49:38:
> BdC> Hi Alister, André,
> BdC> Thanks for the response to the plugin.
> BdC> Alister, a new version (0.0.2) of the plugin is available at the same
> BdC> address [1] with your CRS suggestion implemented.
> BdC> [1] http://www.bc-consult.com/free/bccshpv.html
> BdC> Cheers,
> BdC> Benoit
> >> From: qgis-user-bounces at lists.osgeo.org
> >> [mailto:qgis-user-bounces at lists.osgeo.org]On Behalf Of Alister Hood
> >> Sent: Thursday, 26 August 2010 06:03
> >> To: qgis-user at lists.osgeo.org
> >> Subject: [Qgis-user] RE: Shapefile structure viewer and editor plugin
> >> Thanks for this Benoit; it is fantastic.
> >> We often need to extract the coordinates (and attributes) from a
> >> point shapefile, and put them in a spreadsheet. This was one of
> >> two things I still did in a proprietary GIS, but your plugin
> >> gives me a much quicker and more straightforward way of doing it.
> >> Have you considered displaying the CRS at the top?
> >> Regards,
> >> Alister
> >> 2010/8/24 Benoit de Cabissole <benoit at exigesa.com>
> >> > Hello List,
> >> > I've created a simple plugin that allows to view the structure of a
> >> > shapefile (X-, Y-coords alongside its attributes) and while at
> >> it I've also
> >> > added the capability to edit the geometry and attributes and
> >> save back to
> >> > the shapefile.
> >> > A corollary is that if you want to add a point by typing its
> >> coords you can
> >> > do it with the plugin (as André aka ALT SHN has suggested).
> You can even
> >> > create a new shapefile in QGIS and use the plugin to type in
> coords and
> >> > attributes or paste them from the clipboard.
> >> > Points, lines and polygons shapefiles can be manipulated.
> >> > BUT, I feel it is a quite dangerous plugin to release in a
> public repo
> >> > because of the potential damages bad edits can do on a shapefile!
> >> > I would thus be very grateful if the most intrepid amongst you
> >> could test
> >> > it and give comments on its usefulness...
> >> > The plugin is available at the address below:
> >> > Cheers,
> >> > Benoit
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> BdC> _______________________________________________
> BdC> Qgis-user mailing list
> BdC> Qgis-user at lists.osgeo.org
> BdC> http://lists.osgeo.org/mailman/listinfo/qgis-user
