[Qgis-user] Map books
Andreas Neumann a.neumann at carto.net
Thu Aug 26 13:00:23 PDT 2010
  Hi Tom,
Do you mean, you want to generate an atlas, or a serial print?
QGIS doesn't support this out of the box, but it should be somehow
possible with Python scripting. Most of the print composer should be
exposed for Python, so you can place all your map layout elements, such
as scalebar, gridlines, etc. with Python, generate images and then use
something like XSL-FO, or ODF to generate a book out of it.
A serial print would be an interesting future feature though. It would,
for example also be nice if one could specify a linear feature (or group
of selected features), e.g. a freeway or a powerline, and QGIS would
automagically tile and serial print along this feature ... would be nice
to have ;-) For a regular grid, potentially with some small overlap, it
should be easier.
Sorry that I can't help more.
Andreas
On 8/26/10 6:06 PM, Tom White wrote:
> Hello, all.
> I'm trying to make map books for a volunteer fire station. I've done
> it in another (commercial) package, and it goes something like this:
> Divide the area up into reasonably sized rectangles, with an aspect
> ratio similar to the final page size (for instance, 2x3 arc seconds).
> Create page images (with labeling as detailed as possible)
> Create page feature dumps (basically a list of features on the page
> that are then tied back to an index)
> And from there it's imagemagick, textutils and other hacks to get it
> into a book format.
> Has anyone attempted to make any sort of map books with QGis, or does
> anybody know how it might be done?
> Qgis-user mailing list
