[Qgis-user] TXT TO SHP
Stefan Kiefer st_kiefer at web.de
Thu Aug 26 23:57:55 PDT 2010
What format has the txt file? The file should have a header to get all
da to import a delimited text it should be composed from at least a x
and y coordinate. You have to give the delimiter (probably a "," or
maybe a tabulator = \t . If you now select a file, then you can chose
the x resp. y column in the listboxes. If that not works be sure that
the coordinates are written in british system, I mean decimal values
delimited by a ".". For me this works perfectly.
If  you have further trouble please post the composition of the text
file.
cheers
Stefan
Am Donnerstag, den 26.08.2010, 20:49 -0700 schrieb john:
> HELLO ALL,
>    ANY ONE KNOW AN EASY WAY TO DISPLAY A TXT FILE WITH LONGLAT CO-ORDS
> AS A SHP FILE IN QGIS AND THEN CONTOUR ATTRIBUTES WITH VALUES IN
> SIMILAR RANGES? I'VE TRIED THE PLUGIN, ADD DELIMETED TEXT, BUT WENT
> AROUND IN CIRCLES AND EVENTUALLY CRASHED MY 1.5.0 VERSION. ANY
> SUGGESTIONS WILL BE GREATLY APPRECIATED.
>    J.R.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100827/cd5012a1/attachment.html>
