[Qgis-user] adding txt as shape
Micha Silver micha at arava.co.il
Sat Aug 28 10:59:56 PDT 2010
On 28/08/2010 20:19, john wrote:
> Hello Stephan,
>    Thanks for the file. When I change delimeter to \t and import to an
> open project using the plugin it briefly shows it as an added layer
> with symbology and then crashes the program with the message " has
> caused the program to stop working correctly, windows is searching for
> a solution... etc". I know I must be missing something obvious but 2
> hours of trying different things leads nowhere. Any suggestions will
> of course be received with much gratitude.
>    thanks,
>    J.R
Can you post your text file - at least the first several lines - here on
the list or somewhere, so we can check?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100828/da5ba569/attachment.html>
