[Qgis-user] EasyPrint Plugin
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Mon Aug 9 15:38:30 EDT 2010
Hi
release early, release often: I'm working on a plugin that should help
you creating print compositions. Something like the QuickPrint plugin.
The main idea was to create a push button solution with some
flexibility. The user can define the available paper sizes and scales in
an XML file (preferences/preferences.xml). And there is some basic
support for creating your own layouts (layouts/layouts.xml); eg. footer,
header, text, icons, arrows etc. These layouts should then work with all
available papersizes.
The plugin can be found here: http://www.catais.org/qgis/plugins.xml
There are some PDFs which are created with the available layouts in the
plugin:
http://www.catais.org/qgis/easyprint/pdf/easyprint1.pdf
http://www.catais.org/qgis/easyprint/pdf/easyprint2.pdf
http://www.catais.org/qgis/easyprint/pdf/easyprint3.pdf
Compare these PDFs with the layouts defined in the layouts.xml file and
you should get a first impression how it works. This may help a bit:
http://www.catais.org/qgis/easyprint/svg/easyprint_portrait.svg
It does not run on Mac OS X :-( There seems to be a bug in Qt or PyQt...
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler at bd.so.ch
http://www.so.ch
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20100809/79fdbbec/attachment.html
