[Qgis-user] Trying to get the wktraster plugin to work
Maurício de Paulo mauricio.dev at gmail.com
Wed Dec 1 11:58:23 PST 2010
Thanks jorge!
Then I figure it's a bug in the plugin. I wrote the wrong modes. I'm fixing
and updating.
Hum... I'm going to wait for your responde on the parsing part. If not,
should I parse it on the plugin?
Best regards,
Mauricio de Paulo
2010/12/1 Jorge Arévalo <jorge.arevalo at deimos-space.com>
> Hello,
> On Wed, Dec 1, 2010 at 7:19 PM, Maurício de Paulo
> <mauricio.dev at gmail.com> wrote:
> > Hi Andreas,
> > As you were able to load the raster metadata i'm assuming you installed
> the
> > wktraster sql on the database.
> > I've never tested myself on postgresql 9.0.
> > Do you have a postgresql 8.4 instance to test too? Just to be sure if
> it's a
> > gdal incompatibility with 9.0.
> > Thanks for the information, I'm repassing to Jorge (GDAL's developper).
> > Best regards,
> > Mauricio de Paulo
> >> Hi,
> >> I am trying to get the wktraster plugin to work.
> >> The initial connection to the db is fine. It lists all my raster
> datasets
> >> I have in the db.
> >> After selecting a raster (and adding the schema-name in front of the
> >> table-name) I hit ok and after entering the password again, I get the
> >> following error message:
> >> Could not load PG: dbname=uster host=localhost user=an password=xxx
> >> port=5432 table=dtm.dtmav mode=1
> >> In the console that started QGIS I get a warning:
> >> Warning: This version of PostgreSQL is not supported and may not work.
> >> ERROR 1: Error browsing database for PostGIS Raster properties
> >> Here is my Postgres/Postgis version string:
> >> "PostgreSQL 9.0.1 on x86_64-unknown-linux-gnu, compiled by GCC gcc
> (Ubuntu
> >> 4.4.3-4ubuntu5) 4.4.3, 64-bit"
> >> "POSTGIS="1.5.2" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
> >> 2009" LIBXML="2.7.6" USE_STATS"
> >> Do you have any idea what may be wrong here? Is PostgreSQL 9.0 not
> >> supported? It works fine with my other QGIS projects ...
> >> Thanks,
> >> Andreas
> >> Andreas Neumann
> >> http://www.carto.net/neumann/
> >> http://www.svgopen.org/
> > Mauricio de Paulo
> > Engenheiro Cartografo
> I assume you're using the new version of GDAL driver, commited on
> release 20912 (http://trac.osgeo.org/gdal/changeset/20912). The right
> syntax for the connection string should be
> PG:"dbname=uster host=localhost user=an password=xxx port=5432
> schema=dtm table=dtmav mode=1"
> instead of
> PG: dbname=uster host=localhost user=an password=xxx port=5432
> With this string, you'll read the rows of the table dtmav, schema dtm,
> as different raster files. So, the driver will report these rows as
> subdatasets. If you use mode=2, all the rows are considered as tiles
> of a bigger raster coverage.
> Anyway, let me check if the driver parses the
> "table=<schema>.<table_name>" syntax. I can't remember it.
> Jorge Arévalo
> Internet & Mobilty Division, DEIMOS
> http://mobility.grupodeimos.com/
> http://gis4free.wordpress.com
Mauricio de Paulo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101201/2a481c8f/attachment.html>
