[Qgis-user] scale dependend representation?
a.neumann at carto.net a.neumann at carto.net
Tue Dec 28 04:15:13 PST 2010
 Hi Sven
 Each rule can also hold a scale range (min/max). You can have multiple
 scale ranges per layer.
 In your case, one rule would contain the intended scale range and the
 filter (like an SQL-WHERE part). In the recent trunk there is also a
 graphical query builder now.
 The other rule would hold the consequent scale range and a different
 filter/SQL-WHERE part.
 To enable the rule-based renderer, choose "New Symbology" and then
 "rule based renderer". There is a button with a green "plus" to add a
 new rule. In the new dialogue you can then define a scale range and the
 SQL where part.
 Hope this helps?
 Andreas
 On Tue, 28 Dec 2010 12:39:14 +0100, Sven Bauhan wrote:
> Hi,
> I am trying to configure a layer, so that it shows different sized
> objects
> related to the actual scale of the map. I saw that there is the
> possibility to
> configure a rule based representation. But I could not figure out how
> i can be
> used to act scale based.
> For example I have a layer with airports. When I see the whole layer
> I just
> want to display the biggest airports. When I zoom into the map the
> smaller
> airports up to all little heliports shall become visible depending on
> the
> scale factor.
> Can someone tell me how i can configure a scale based representation?
> Thanks,
> Sven
> Qgis-user mailing list
