[Qgis-user] Problem with kml file
Siki Zoltan siki at agt.bme.hu
Thu Dec 23 17:13:01 EST 2010
AFAIK no
regards,
Zoltan
On Thu, 23 Dec 2010, Agustin Lobo wrote:
> Thanks!
> Any way I can reformat the file? This file has been given to me, no way I
> can modify the options of the gps now.
> Or perhaps there is a way to tell gdal-OGR the file has html format
> and then write a shapefile?
> Agus
> 2010/12/23 Siki Zoltan <siki at agt.bme.hu>:
>> Dear Augustin,
>> you have html code in the description field of the xml.
>> You sould display them in a browser e.g. FireFox.
>> Or you should change the export configuration of your software/GPS to have
>> plan txt.
>> I've attached a sniplet from your xml in html and an image in my browser.
>> regards,
>> Zoltan
>>> Hi!
>>> I have a problem with a kmz [1] (unzipped to kml [2]) file that once
>>> imported to QGIS
>>> has a table plenty of control characters etc [3]. I would appreciate
>>> if someone knowing the
>>> format could give a look to the kml file and tell me if the file is
>>> defective or
>>> we have a problem at importing some of them to QGIS, perhaps there are
>>> different versions of kml.
>>> The files are
>>> [1] https://sites.google.com/site/filestemp2/home/fluxpyr_221010_1.kmz
>>> [2] https://sites.google.com/site/filestemp2/home/fluxpyr_221010_1.kml
>>> [3] https://sites.google.com/site/filestemp2/home/kmlproblem.jpeg
>>> Thanks!
>>> Agus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
