[Qgis-user] Qgis 1.4.0 crashes on debian squeeze
Guy Roussin guy.roussin at teledetection.fr
Wed Feb 17 04:48:54 PST 2010
Hi Stephano,
Same here (squeeze amd64, same log with strace),
So i install sid version of qgis ... no more crash.
Guy
Stefano De Toni a écrit :
> Hi!
> I'm using debian squeeze and untill some weeks ago I've used qgis from
> lenny repository without big problems: I had only to install
> libgdal1-1.5.0-grass and downgrade grass to version 6.4.0~rc4-3.
> Now I cannot have qgis working.
> The tail of
> strace qgis
> is:
> _____________________________
> stat64("/usr/lib/pymodules/python2.5/PyQt4/QtGui", 0xbfc8d130) = -1
> ENOENT (No such file or directory)
> open("/usr/lib/pymodules/python2.5/PyQt4/QtGui.so",
> O_RDONLY|O_LARGEFILE) = 18
> fstat64(18, {st_mode=S_IFREG|0644, st_size=6887056, ...}) = 0
> open("/usr/lib/pymodules/python2.5/PyQt4/QtGui.so", O_RDONLY) = 19
> read(19,
> "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\177\16\0004\0\0\0"...,
> 512) = 512
> fstat64(19, {st_mode=S_IFREG|0644, st_size=6887056, ...}) = 0
> mmap2(NULL, 6886236, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE,
> 19, 0) = 0xb05a3000
> mmap2(0xb0bdb000, 368640, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 19, 0x638) = 0xb0bdb000
> close(19)                               = 0
> brk(0x88d5000)                          = 0x88d5000
> brk(0x88f6000)                          = 0x88f6000
> brk(0x8917000)                          = 0x8917000
> close(18)                               = 0
> stat64("/usr/share/qgis/python/qgis", 0xbfc8d130) = -1 ENOENT (No such
> file or directory)
> open("/usr/share/qgis/python/qgis.so", O_RDONLY|O_LARGEFILE) = -1
> open("/usr/share/qgis/python/qgismodule.so", O_RDONLY|O_LARGEFILE) =
> -1 ENOENT (No such file or directory)
> open("/usr/share/qgis/python/qgis.py", O_RDONLY|O_LARGEFILE) = -1
> open("/usr/share/qgis/python/qgis.pyc", O_RDONLY|O_LARGEFILE) = -1
> stat64("/usr/share/qgis/python/plugins/qgis", 0xbfc8d130) = -1 ENOENT
> open("/usr/share/qgis/python/plugins/qgis.so", O_RDONLY|O_LARGEFILE) =
> open("/usr/share/qgis/python/plugins/qgismodule.so",
> O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
> open("/usr/share/qgis/python/plugins/qgis.py", O_RDONLY|O_LARGEFILE) =
> open("/usr/share/qgis/python/plugins/qgis.pyc", O_RDONLY|O_LARGEFILE)
> stat64("/usr/lib/python2.5/qgis", 0xbfc8d130) = -1 ENOENT (No such
> file or directory)
> open("/usr/lib/python2.5/qgis.so", O_RDONLY|O_LARGEFILE) = -1 ENOENT
> open("/usr/lib/python2.5/qgismodule.so", O_RDONLY|O_LARGEFILE) = -1
> open("/usr/lib/python2.5/qgis.py", O_RDONLY|O_LARGEFILE) = -1 ENOENT
> open("/usr/lib/python2.5/qgis.pyc", O_RDONLY|O_LARGEFILE) = -1 ENOENT
> stat64("/usr/lib/python2.5/plat-linux2/qgis", 0xbfc8d130) = -1 ENOENT
> open("/usr/lib/python2.5/plat-linux2/qgis.so", O_RDONLY|O_LARGEFILE) =
> open("/usr/lib/python2.5/plat-linux2/qgismodule.so",
> open("/usr/lib/python2.5/plat-linux2/qgis.py", O_RDONLY|O_LARGEFILE) =
> open("/usr/lib/python2.5/plat-linux2/qgis.pyc", O_RDONLY|O_LARGEFILE)
> stat64("/usr/lib/python2.5/lib-tk/qgis", 0xbfc8d130) = -1 ENOENT (No
> open("/usr/lib/python2.5/lib-tk/qgis.so", O_RDONLY|O_LARGEFILE) = -1
> open("/usr/lib/python2.5/lib-tk/qgismodule.so", O_RDONLY|O_LARGEFILE)
> open("/usr/lib/python2.5/lib-tk/qgis.py", O_RDONLY|O_LARGEFILE) = -1
> open("/usr/lib/python2.5/lib-tk/qgis.pyc", O_RDONLY|O_LARGEFILE) = -1
> stat64("/usr/lib/python2.5/lib-dynload/qgis", 0xbfc8d130) = -1 ENOENT
> open("/usr/lib/python2.5/lib-dynload/qgis.so", O_RDONLY|O_LARGEFILE) =
> open("/usr/lib/python2.5/lib-dynload/qgismodule.so",
> open("/usr/lib/python2.5/lib-dynload/qgis.py", O_RDONLY|O_LARGEFILE) =
> open("/usr/lib/python2.5/lib-dynload/qgis.pyc", O_RDONLY|O_LARGEFILE)
> stat64("/usr/local/lib/python2.5/site-packages/qgis", 0xbfc8d130) = -1
> open("/usr/local/lib/python2.5/site-packages/qgis.so",
> open("/usr/local/lib/python2.5/site-packages/qgismodule.so",
> open("/usr/local/lib/python2.5/site-packages/qgis.py",
> open("/usr/local/lib/python2.5/site-packages/qgis.pyc",
> stat64("/usr/lib/python2.5/site-packages/qgis", {st_mode=S_IFDIR|0755,
> st_size=4096, ...}) = 0
> stat64("/usr/lib/python2.5/site-packages/qgis/__init__.py",
> {st_mode=S_IFREG|0644, st_size=106, ...}) = 0
> stat64("/usr/lib/python2.5/site-packages/qgis/__init__", 0xbfc8c0d0) =
> open("/usr/lib/python2.5/site-packages/qgis/__init__.so",
> open("/usr/lib/python2.5/site-packages/qgis/__init__module.so",
> open("/usr/lib/python2.5/site-packages/qgis/__init__.py",
> fstat64(18, {st_mode=S_IFREG|0644, st_size=106, ...}) = 0
> open("/usr/lib/python2.5/site-packages/qgis/__init__.pyc",
> O_RDONLY|O_LARGEFILE) = 19
> fstat64(19, {st_mode=S_IFREG|0644, st_size=136, ...}) = 0
> mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1,
> 0) = 0xb307b000
> read(19,
> "\263\362\r\n[}AKc\0\0\0\0\0\0\0\0\1\0\0\0@\0\0\0s\4\0\0\0d\0"...,
> 4096) = 136
> read(19, "", 4096)                      = 0
> close(19)                               = 0
> munmap(0xb307b000, 4096)                = 0
> close(18)                               = 0
> stat64("/usr/lib/python2.5/site-packages/qgis/core", 0xbfc8d130) = -1
> open("/usr/lib/python2.5/site-packages/qgis/core.so",
> fstat64(18, {st_mode=S_IFREG|0644, st_size=1326576, ...}) = 0
> open("/usr/lib/python2.5/site-packages/qgis/core.so", O_RDONLY) = 19
> read(19,
> "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0pD\3\0004\0\0\0"...,
> 512) = 512
> fstat64(19, {st_mode=S_IFREG|0644, st_size=1326576, ...}) = 0
> mmap2(NULL, 1326536, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE,
> 19, 0) = 0xb045f000
> mmap2(0xb058b000, 98304, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 19, 0x12c) = 0xb058b000
> close(19)                               = 0
> brk(0x8938000)                          = 0x8938000
> --- SIGSEGV (Segmentation fault) @ 0 (0) ---
> +++ killed by SIGSEGV +++
> _____________________________________
> The gdb output is:
> ______________________________________
> Reading symbols from /usr/bin/qgis.bin...(no debugging symbols
> found)...done.
> (gdb) run
> Starting program: /usr/bin/qgis.bin
> [Thread debugging using libthread_db enabled]
> [New Thread 0xb2e36b70 (LWP 24579)]
> [Thread 0xb2e36b70 (LWP 24579) exited]
> Program received signal SIGSEGV, Segmentation fault.
> strlen () at ../sysdeps/i386/i486/strlen.S:69
> 69    ../sysdeps/i386/i486/strlen.S: No such file or directory.
>    in ../sysdeps/i386/i486/strlen.S
> Current language:  auto
> The current source language is "auto; currently asm".
> ________________________________________________________
> And finally the configuration of my packages is:
> -- System Information:
> Debian Release: squeeze/sid
>  APT prefers squeeze
>  APT policy: (500, 'squeeze'), (500, 'testing')
> Architecture: i386 (i686)
> Kernel: Linux 2.6.32-trunk-686 (SMP w/2 CPU cores)
> Locale: LANG=en_US, LC_CTYPE=en_US (charmap=ISO-8859-1)
> Shell: /bin/sh linked to /bin/bash
> Versions of packages qgis depends on:
> ii  libc6            2.10.2-2                GNU C Library: Shared
> libraries
> ii  libexpat1        2.0.1-7                 XML parsing C library -
> runtime li
> ii  libgcc1          1:4.4.2-9               GCC support library
> ii  libgdal1-1.6.0   1.6.3-1                 Geospatial Data
> Abstraction Librar
> ii  libgeos-c1       3.1.0-1                 Geometry engine for
> Geographic Inf
> ii  libgsl0ldbl      1.13+dfsg-1             GNU Scientific Library
> (GSL) -- li
> ii  libpq5           8.4.2-2                 PostgreSQL C client library
> ii  libproj0         4.7.0-1                 Cartographic projection
> library
> ii  libqgis1.4.0     1.4.0~gfossit20100106-1 Quantum GIS - shared
> libraries
> ii  libqt4-network   4:4.5.3-4               Qt 4 network module
> ii  libqt4-sql       4:4.5.3-4               Qt 4 SQL module
> ii  libqt4-svg       4:4.5.3-4               Qt 4 SVG module
> ii  libqt4-webkit    4:4.5.3-4               Qt 4 WebKit module
> ii  libqt4-xml       4:4.5.3-4               Qt 4 XML module
> ii  libqtcore4       4:4.5.3-4               Qt 4 core module
> ii  libqtgui4        4:4.5.3-4               Qt 4 GUI module
> ii  libstdc++6       4.4.2-9                 The GNU Standard C++
> Library v3
> ii  qgis-common      1.4.0~gfossit20100106-1 Quantum GIS -
> architecture-indepen
> Versions of packages qgis recommends:
> ii  python-qgis      1.4.0~gfossit20100106-1 Python bindings to
> Quantum GIS
> ii  qgis-plugin-gras 1.4.0~gfossit20100106-1 GRASS plugin for Quantum GIS
> Versions of packages qgis suggests:
> ii  gpsbabel                      1.3.6-3    GPS file conversion plus
> transfer
> -- no debconf information
> Any suggestion?
> Thanks
> Stefano De Toni
> Qgis-user mailing list
