[Qgis-user] Problems with projections
GISBOX gisbox at web.de
Fri Feb 19 11:50:43 PST 2010
Hi Mike,
your shapefile is in a lokal projection different from the offical EPSG and
the prj file is wrong. The data is in zone 7 and the prj file are for zone 5.
EPSG:3331 or EPSG:2641 are better.
You have to know what towgs84 parameters the dataset use. There are no Pulkovo
based data definitions without towgs84 parameters.
gretings
Ralf
Am Freitag 19 Februar 2010 12:36:15 schrieb jamesmikedupont at googlemail.com:
> On Fri, Feb 19, 2010 at 12:29 PM, Micha Silver <micha at arava.co.il> wrote:
> >  you tried just installing the Ubuntu binaries? When did these problems
> > start happening?
> These problems are with these binaries,
> #deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu karmic
> main
> #deb-src http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
> karmic main
> Which should I be using? I dont see standard ones in ubuntu-
> > Are you on the qgis-developer  maillist? You'd probably get better
> > responses there.
> > Thanks, will do.
