[Qgis-user] Re: problems building qgis 1.4.0
Neil Best nbest at ci.uchicago.edu
Tue Feb 23 08:03:09 PST 2010
Marco Hugentobler wrote:
> Does it help if you add
> #include <cmath>
> to src/app/qgsmaptoolrotatepointsymbols.cpp?
> If it does, I'll add it to svn.
Thanks, Marco, that did help.  Now I have a new error!
[ 35%] Building CXX object
src/app/CMakeFiles/qgis.dir/composer/qgscomposer.cpp.o
/home/nbest/src/qgis_1.4.0/build/src/app/../ui/ui_qgscomposerlegendwidgetbase.h:
In member function ‘void Ui_QgsComposerLegendWidgetBase::setupUi(QWidget*)’:
/home/nbest/src/qgis_1.4.0/build/src/app/../ui/ui_qgscomposerlegendwidgetbase.h:174:
error: ‘class QTreeView’ has no member named ‘setHeaderHidden’
/home/nbest/src/qgis_1.4.0/src/app/composer/qgscomposer.cpp: In member
function ‘void QgsComposer::on_mActionExportAsPDF_triggered()’:
/home/nbest/src/qgis_1.4.0/src/app/composer/qgscomposer.cpp:480: error:
‘class QPrinter’ has no member named ‘setPaperSize’
‘Millimeter’ is not a member of ‘QPrinter’
function ‘void QgsComposer::on_mActionPrint_triggered()’:
/home/nbest/src/qgis_1.4.0/src/app/composer/qgscomposer.cpp:499: error:
function ‘void QgsComposer::print(QPrinter&)’:
/home/nbest/src/qgis_1.4.0/src/app/composer/qgscomposer.cpp:539: warning:
passing ‘double’ for argument 1 to ‘void QImage::setDotsPerMeterX(int)’
/home/nbest/src/qgis_1.4.0/src/app/composer/qgscomposer.cpp:540: warning:
passing ‘double’ for argument 1 to ‘void QImage::setDotsPerMeterY(int)’
function ‘void QgsComposer::on_mActionExportAsImage_triggered()’:
/home/nbest/src/qgis_1.4.0/src/app/composer/qgscomposer.cpp:682: warning:
/home/nbest/src/qgis_1.4.0/src/app/composer/qgscomposer.cpp:683: warning:
make[2]: *** [src/app/CMakeFiles/qgis.dir/composer/qgscomposer.cpp.o] Error
1
make[1]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
make: *** [all] Error 2
Any idea what's happening here?
View this message in context: http://n2.nabble.com/problems-building-qgis-1-4-0-tp4613379p4619708.html
Sent from the qgis-user mailing list archive at Nabble.com.
