[Qgis-user] Re: problems building qgis 1.4.0
Neil Best nbest at ci.uchicago.edu
Tue Feb 23 08:37:29 PST 2010
On Feb 23, 2010, at 10:27 AM, Jürgen E. Fischer wrote:
> On Tue, 23. Feb 2010 at 08:03:09 -0800, Neil Best wrote:
>> src/app/CMakeFiles/qgis.dir/composer/qgscomposer.cpp.o
>> /home/nbest/src/qgis_1.4.0/build/src/app/../ui/
>> ui_qgscomposerlegendwidgetbase.h:
>> In member function ???void
>> Ui_QgsComposerLegendWidgetBase::setupUi(QWidget*)???:
>> ui_qgscomposerlegendwidgetbase.h:174:
>> error: ???class QTreeView??? has no member named ???
>> setHeaderHidden???
> Looks like #2121.   Are you using Qt 4.3?   IIRC we need at least Qt
> 4.4.
Yes, 4.3.5-r1.  How can we confirm this requirement?  I looked through
qgis_1.4.0/INSTALL a bit but didn't see it spelled out.  I'll look
into an upgrade.  Thanks for the tip, Marco and Jürgen.
