[Qgis-user] proj file and QGIS
Werner Macho
werner.macho at gmail.com
Mon Feb 22 06:53:09 EST 2010
To all developers! correct me if i am wrong.
It seems to me that sometimes QGIS does not "understand" the proj file
if it comes from ESRI products ..
I have had a simmilar problem with some data here when Otto Dassau
helped me cleaning out the problem ..
But to be honest - I'm completely with you when you say QGIS should at
least set the projection somehow automatically.
IIRC we had such discussions a few month ago .. So probably this is a
topic for the hackfest in Pisa?
Paolo? What do you think about it?
regards
Werner
Am 22.02.2010 12:32, schrieb Yves Jacolin:
> Hello,
> It seems i get a strange (for me) behaviours with QGIS.
> Does QGIS is supposed to read proj file and use it as projection data when
> opening a shapefile?
> I have never seen QGIS get the correct projection for a shapefil, but it seems
> QGIS should do it. Am I wrong?
> Thanks,
> Y.
