[Qgis-user] CAD functions plugin
John C. Tull
john.tull at wildnevada.org
Sun Jan 3 20:40:23 PST 2010
Hi Stefan,
I tried your plugin this evening on my OS X system. I was most interested in the orthogonal editing feature. Based on the instructions, I used the control key as a modifier to draw my polygon. This did not work. Instead, it appears that the command key is the correct modifier on Mac systems; it seemed to work correctly using that. Here is the error produced from the control key:
An error has occured while executing Python code:
File "/Users/jctull/.qgis//python/plugins/cadtools/orthogonaltool.py", line 63, in canvasPressEvent
self.createFeature()
File "/Users/jctull/.qgis//python/plugins/cadtools/orthogonaltool.py", line 98, in createFeature
f.setGeometry(g)
TypeError: argument 1 of QgsFeature.setGeometry() has an invalid type
Python version:
2.6.1 (r261:67515, Jul 7 2009, 23:51:51)
[GCC 4.2.1 (Apple Inc. build 5646)]
Python path: ['/Applications/qgis1.5.0.app/Contents/MacOS/share/qgis/python', '/Users/jctull/.qgis//python', '/Users/jctull/.qgis//python/plugins', '/Applications/qgis1.5.0.app/Contents/MacOS/share/qgis/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/3/Python', '/Library/Frameworks/Mapnik.framework/Versions/Current/Python/System/2.6/dist-packages', '/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-packages', '/Library/Python/2.6/site-packages/pyparsing-1.5.2-py2.6.egg', '/Library/Python/2.6/site-packages/scipy-0.7.1-py2.6-macosx-10.6-universal.egg', '/Library/Python/2.6/site-packages/rpy2-2.0.8-py2.6-macosx-10.6-universal.egg', '/Library/Python/2.6/site-packages/setuptools-0.6c11-py2.6.egg', '/Library/Python/2.6/site-packages/py2app-0.4.3-py2.6.egg', '/Library/Python/2.6/site-packages/macholib-1.2.1-py2.6.egg', '/Library/Python/2.6/site-packages/modulegraph-0.7.3-py2.6.egg', '/Library/Python/2.6/site-packages/OWSLib-0.3.1-py2.6.egg', '/Library/Python/2.6/site-packages/lxml-2.2.4-py2.6-macosx-10.6-universal.egg', '/Library/Python/2.6/site-packages/nose-0.11.1-py2.6.egg', '/Library/Python/2.6/site-packages/pyamg-1.0.0-py2.6-macosx-10.6-universal.egg', '/Library/Python/2.6/site-packages/numpy-1.3.0-py2.6-macosx-10.6-universal.egg', '/Library/Frameworks/cairo.framework/Versions/1/Python', '/usr/local/lib/python2.6/site-packages', '/System/Library/Frameworks/Python.framework/Versions/Current/lib/python2.6/site-packages', '/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload', '/Library/Python/2.6/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode', '/Applications/qgis1.5.0.app/Contents/MacOS/share/qgis/python/plugins/fTools/tools', '/Users/jctull/.qgis/python/plugins/GdalTools/tools', '/Users/jctull/Documents/John 2007/NWP/Energy Info/Fast_Track_Mapping/Amargosa_Farm_Road']
Cheers,
John
On Jan 1, 2010, at 6:30 AM, Ziegler Stefan wrote:
> Hi
> I started working on a plugin that provides some CAD functions:
> 1. Intersections of linesegments (that do not intersect)
> 2. Arc Intersection
> 3. Orthogonal digitizing
> Repository: http://www.catais.org/qgis/plugins.xml
> Information: http://www.catais.org/qgis/cadtools
> regards
> Stefan
> Mit freundlichem Gruss
> Stefan Ziegler
> Leiter Aufsicht
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> Rötistrasse 4
> 4501 Solothurn
> Telefon 032 627 75 96
> Telefax 032 627 75 98
> stefan.ziegler at bd.so.ch
> http://www.so.ch
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100103/823aa838/attachment.html>
