AW: Re: [Qgis-user] CAD funtions plugin
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Tue Jan 5 22:43:59 PST 2010
Hi Piotr
I'm already working on number 3. Number 2 is a bit more surveying stuff
but I also would like to see it in QGIS. For this tool there should be
also an import function for some common data formats (e.g. GSI etc.
etc.). And perhaps a function to take the mean if you measure the same
point twice. Ah and some 2D helmert if the station point is unknown.
Definitely too many new layers. I will try to store all the new objects
in a cadtools point or line layer.
Thanks for your input.
regards
Stefan
   -----Ursprüngliche Nachricht-----
   Von: piotr.pachol at wodgik.katowice.pl
   [mailto:piotr.pachol at wodgik.katowice.pl]
   Gesendet am: Dienstag, 5. Januar 2010 16:10
   An: Ziegler Stefan
   Cc: qgis-user at lists.osgeo.org
   Betreff: Re: [Qgis-user] CAD funtions plugin
   Hello Stefan,
   I am very happy that you add some  CAD  functions do Qgis.
   They are really useful, but still I feel lack of another CAD funtions
   in Qgis.
   What I really need is:
   1. Adding new objects entering coordinates (in point, line or polygon
   layer) just from keybord.
   2. Polar measuremets: we have station point, reference point and we
   enter distance and angle to  get coordinates of calculated point.
   3. Rectangular measurements (sometimes still useful): we have station
   point, reference point and we enter 2 distances (abscissa, ordinate)
   4. Intersection from 2 points when you know two angles to set point
   (in your plugin there is arc intersection when you know 2 distances
   to set point).
   5. Reverse intersection from 3 points (based on distances or angles).
   First 3 points a really important.
   What do you think about it ?
   As to functionality of your plugin now each new created intersection
   (orthogonal) point or line is on new layer. It is bothering when I
   want to further use a group of new created objects.
   So I would suggest:
   1. Add some setting options, where user may point out (enter name of)
   only 2 layers (point layer and line layer) where objects are written
   (with intersection or orthogonal  line and point).
   2. Or second solution: to make editable in the same time 2 layers
   (with points and lines) and to add new objects (intersection or
   orthogonal lines and points) at these editable layers.
   Regards,
   Piotr
   Ziegler Stefan pisze:
      Hi
      I started working on a plugin that provides some CAD functions:
      1. Intersections of linesegments (that do not intersect)
      2. Arc Intersection
      3. Orthogonal digitizing
      I added another function to the plugin:
      4. Orthogonal Line: draw an orthogonal line from a point to a line
      segment.
      Repository: http://www.catais.org/qgis/plugins.xml
      Information: http://www.catais.org/qgis/cadtools
      regards
      Stefan
      Mit freundlichem Gruss
      Stefan Ziegler
      Leiter Aufsicht
      Kanton Solothurn
      Bau- und Justizdepartement
      Amt für Geoinformation
      Rötistrasse 4
      4501 Solothurn
      Telefon 032 627 75 96
      Telefax 032 627 75 98
      stefan.ziegler at bd.so.ch
      http://www.so.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100106/e706b147/attachment.html>
