[Qgis-user] GDAL and .nc (netCDF) and qgis
Mike Toews mwtoews at sfu.ca
Thu Jan 7 10:19:16 PST 2010
M.E.Dodd wrote:
> I would like to open some large gridded met data files, produce means of the values for each grid square (data for each square are given each year for a number of years and I want a mean of all the years) and write the data out again showing just the means per grid square.
I would look at other tools for doing calculations on multi-dimensional
NetCDF files. I've used NCO in the past for this,[1] which can average a
time dimension in a 3D grid to produce a 2D grid (which can be converted
to any other raster format using GDAL). You can do much more with NCO
utilities. However, NCO is not user-friendly, since it is command-line
work, requires a lot of documentation reading to understand the usage,
and is available for almost all operating systems except MS Windows.
[1] http://nco.sourceforge.net
-Mike
