[Qgis-user] Hello
Pierre Chevalier Géologue pierrechevaliergeol at free.fr
Wed Jan 13 00:29:52 PST 2010
Good morning,
Brett Adams claviota:
> Hi Pierre,
> I'm a geophysicist in Australia, working primarily in Nickel and IOCG.
> Just started my own consultantsy this year and started with Qgis last
> week. My requirements of Qgis sound very similar to yours.
Certainly.  You geophysicists like bright colours, and we geologists
have more dull colours, but after all, we are dealing with the same
thing: rocks, displayed on maps! ;)
So I believe we should have similar requirements!
> How are you getting a coordinate grid around your maps?
Not easily.  Usually, I generate several graticules using the
appropriate plugin, which creates a shapefile for each graticule.  I
have to manually change the srid, and then I overlay all my graticules,
using different transparencies, to get a neat visual effect.  I also
play with labels, according to map scale and the step of graticule.
> I'm hoping you have a better (faster) system than me.
I'm afraid not... ;(
> My process works but is a bit of stuffing about. I generate a vector
> grid, edit the DBF file, reimport the DBF then get the labels organised.
All right: then, you end up with points with a little cross symbol, if I
understand well, with labels around them.
I believe this is a feature that would be needed by many of us, qgis
users.  I had the plan to try to write a plugin to do a neat graticule,
generated every time the map is changed, with coordinates every 1km, or
100m, or 1000km, depending on the zoom, or 1°, or 30", etc. depending on
the srid (which may be different from the map).  But no time...
So many software packages already do this neatly, so I guess it should
not be too difficult to adapt their code.  I'm thinking of viking, for
instance.
A+
Pierre
____________________________________________________________________________
Pierre Chevalier Géologue EI
    Mesté Duran
    32100 Condom
  Tél+fax  :    09 75 27 45 62
                05 62 28 06 83
		06 37 80 33 64
  Émail  :   pierrechevaliergeolCHEZfree.fr
  icq#   :   10432285
  skype  :   pierre.chevalier1967
  http://pierremariechevalier.free.fr/pierre_chevalier_geologue
