[Qgis-user] kmz in qgis
maning sambale emmanuel.sambale at gmail.com
Wed Jan 13 01:37:59 PST 2010
No it's not.
kmz as well as kmls containing a mixture of placemarks, lines and
polygons.  In order to load kmls in QGIS or use ogr, you should create
separate files for each vector type.
hope that helps.
On Wed, Jan 13, 2010 at 5:25 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Is not possible to open a kmz file in qgis?
> or am I not seeing an obvious option?
> I've tried with OGR converter also.
> Thanks
> Agus
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
